<< Click to Display Table of Contents >> ColumnWidths |
This property is used to specify an object's column width, in points. A value equal to -1 (minus one) or blank forces the width to be calculated on the column. The minimum width on a calculated column is 72 points, or 1 (one) inch. A value equal to 0 (zero) hides a column. To produce narrower columns, users must specify a width in this property or use one of the values described on the next table.
Available options for the ColumnWidths property
Option |
Description |
90;72;90 |
The first column is 90 points (1.25 inches), the second column is 72 points (one inch), and the third column is 90 points |
6 cm;0;6 cm |
The first column is 6 (six) centimeters, the second column is hidden, and the third column is 6 (six) centimeters. As part of the third column is visible, a horizontal scroll bar is visible |
1.5 in;0;2.5 in |
The first column is 1.5 inches, the second column is hidden, and the third column is 2.5 inches |
2 in;;2 in |
The first column is 2 (two) inches, the second column is 1 (one) inch (default), and the third column is 2 (two) inches. As only half of the third column is visible, a horizontal scroll bar is visible |
(Empty) |
All three columns have the same width (1.33 inches). The default value of this property is empty, that is, Elipse E3 uses system's default value |
