StretchText
StretchText
Boolean This property determines the application of a stretch to a Scale's text. If a Scale's width or height change, text follows that change. If this property is enabled, this object follows width and height variations as it is transformed. Otherwise, text maintains its original settings. The default value of this property is False.
