This property, when set to True, allows a Pen to be plotted using an automatic Axis, which receives its minimum and maximum limits from the configuration of a Tag's engineering unit on a server. In this case, the ScaleX (Horizontal Axis) and ScaleY (Vertical Axis) properties are not used.
Feedback
Would you like to provide more information about your experience in this site?
