<< Click to Display Table of Contents >> MinY |
Informs a Pen's minimum value in an interval, if the EnableCalc property is enabled. If an E3Chart is in Interval Search mode, displays the average in this interval. Otherwise, displays the average in the interval between the beginning and the end in the Horizontal Axis. Values with bad quality are not considered if the ShowBadPoints property is disabled. This is a read-only property.
