Shelve
Shelve
Shelve(Duration, Reason, [ActorID])
Shelves only the Alarm or Event from the respective Alarm Source. The Duration parameter indicates the time this Alarm or Event must remain shelved. The Reason parameter indicates a reason for shelving this Alarm or Event. The ActorID parameter indicates the name of the user responsible for shelving. This is an optional parameter and, if omitted, assumes Elipse E3 Viewer's user logon, "Anonymous" if there is no user logged on, or "System" if this method's call started at the server.
