GetAlarm
GetAlarm
GetAlarm()
Returns an object that allows access to specific settings of each type of Alarm. This object allows verifying or changing properties of a certain Alarm at run time. Depending on the type of Alarm, this method returns an object with the properties described on the next tables.
Properties of an Analog Alarm object
Property
Description
ConditionName Text
Name of the alarm condition
Delay Number
Delay time for this Alarm, in milliseconds, when entering and when leaving a condition
Hi Boolean
Enables or disables a verification on this Alarm with a High level of severity
HiAckRequired Boolean
Indicates whether there is a need to acknowledge the High level of severity of this Alarm
HiHi Boolean
Enables or disables a verification on this Alarm with a Very High level of severity
HiHiAckRequired Boolean
Indicates whether there is a need to acknowledge the Very High level of severity of this Alarm
HiHiLimit Number
Limit for the Very High level of severity of this Alarm
HiHiMessageText Text
Text of the message for the Very High level of severity of this Alarm
HiHiSeverity Number
Importance of the Very High level of severity of this Alarm. Possible values for this property are -2: Critical, 0: High, 1: Medium, or 2: Low
HiLimit Number
Limit for the High level of severity of this Alarm
HiMessageText Text
Text of the message for the High level of severity of this Alarm
HiSeverity Number
Importance of the High level of severity of this Alarm. Possible values for this property are -2: Critical, 0: High, 1: Medium, or 2: Low
LevelDeadBand Number
Dead band for limits of this Alarm's level
LevelReturnMessageText Text
Return message of this Alarm
Lo Boolean
Enables or disables a verification on this Alarm with a Low level of severity
LoAckRequired Boolean
Indicates whether there is a need to acknowledge the Low level of severity of this Alarm
LoLimit Number
Limit for the Low level of severity of this Alarm
LoLo Boolean
Enables or disables a verification on this Alarm with a Very Low level of severity
LoLoAckRequired Boolean
Indicates whether there is a need to acknowledge the Very Low level of severity of this Alarm
LoLoLimit Number
Limit for the Very Low level of severity of this Alarm
LoLoMessageText Text
Text of the message for the Very Low level of severity of this Alarm
LoLoSeverity Number
Importance of the Very Low level of severity of this Alarm. Possible values for this property are -2: Critical, 0: High, 1: Medium, or 2: Low
LoMessageText Text
Text of the message for the Low level of severity of this Alarm
LoSeverity Number
Importance of the Low level of severity of this Alarm. Possible values for this property are -2: Critical, 0: High, 1: Medium, or 2: Low
Name Text
Name of this Alarm
Properties of a Dead Band Alarm object
Property
Description
ConditionName Text
DeadBand Boolean
DeadBandAckRequired Boolean
Indicates whether there is a need to acknowledge this Alarm
DeadBandLimit Number
Limit for this Alarm
DeadBandMessageText Text
Text of the message of this Alarm
DeadBandReturnMessageText Text
DeadBandSetPoint Text
Limit of dead band of this Alarm. Each time an associated Tag's value exceeds this property's value above or below DeadBandLimit's value, this Alarm occurs
DeadBandSeverity Number
Importance of this Alarm. Possible values for this property are -2: Critical, 0: High, 1: Medium, or 2: Low
Delay Number
Name Text
Name of this Alarm
Properties of a Digital Alarm object
Property
Description
ConditionName Text
Delay Number
Digital Boolean
DigitalAckRequired Boolean
DigitalLimit Variant
DigitalMessageText Text
DigitalReturnMessageText Text
DigitalSeverity Number
Severity of this Alarm. Possible values for this property are -2: Critical, 0: High, 1: Medium, or 2: Low
Name Text
Name of this Alarm
Properties of a Discrete Alarm object
Property
Description
ConditionName Text
Delay Number
DiscreteReturnMessageText Text
Name Text
Name of this Alarm
SubConditions Collection
A collection of Subconditions of this Alarm. Please check the next table for a description of all available properties on the Subcondition objects of that collection, which are accessible using its Item method
Properties of a Subcondition object from a Discrete Alarm
Property
Description
AckRequired Boolean
Indicates whether there is a need to acknowledge this Subcondition
Caption Text
Description of this Subcondition
Enabled Boolean
Enables or disables this Subcondition
Kind Enum
Behavior of this Subcondition. Possible values for this property are 0: Alarm, 1: Event, or 2: Return
Limit Variant
Value of the Alarm Source to generate this Subcondition
Message Text
Event message when this Subcondition is active
Name Text
Name of this Subcondition
Severity Number
Importance of this Subcondition. Possible values for this property are -2: Critical, 0: High, 1: Medium, or 2: Low
Properties of a Rate of Change Alarm object
Property
Description
ConditionName Text
Delay Number
Name Text
Name of this Alarm
ROC Boolean
ROCAckRequired Boolean
ROCLimit Number
Limit for this Alarm. For this Alarm to occur, it is sufficient that the associated Tag's value exceeds this value in one second
ROCMessageText Text
ROCReturnMessageText Text
ROCSeverity Number
The next code contains an example of using this method.
Sub Button1_Click()
  'Click this Button to change the Low severity level
  'of an Analog Alarm
  Set alm = Application.GetObject("Conf1.Area1.Analog1")_
    .GetAlarm()
  alm.LoLimit = 10.2
NOTE
The properties relative to each type of Alarm can be accessed directly by scripts and Links, as well as viewed on an object's Properties List, so their edition is no longer mandatory via this method.
