Error
Error
Error(Number, Description, SCode, Source, HelpFile, HelpContext, CancelDisplay)
Generated by an object's internal error. If this event is not handled, Elipse E3 displays a generic error message.
Available parameters on the Error event
Name
Description
Number
Integer identifying this error
Description
String with this error's description
SCode
Integer with an error code from the OLE subsystem (not used)
Source
String with the object that generated this error
HelpFile
String with name and path of a help file
HelpContext
Context integer of a help topic referring to this error
CancelDisplay
Boolean indicating whether this error must be displayed on a message box
