<< Click to Display Table of Contents >> MouseUp |
MouseUp(Button, ShiftState, MouseX, MouseY)
This event occurs when a previously clicked mouse button is released. Use this event to determine specific actions to be triggered only when a mouse button is released.
Parameters of the MouseUp event
Name |
Description |
Button |
Displays the pressed mouse button. Possible values are 1: Mouse left button pressed, 2: Mouse right button pressed, or 4: Mouse middle button pressed |
ShiftState |
Displays the pressed key along with the mouse button. Possible values are 4: SHIFT key, 8: CTRL key, or 12: CTRL + SHIFT keys |
MouseX |
Displays Screen's X coordinate where the mouse pointer was clicked |
MouseY |
Displays the Screen's Y coordinate where the mouse pointer was clicked |
The next script contains an example of using this event.
Sub InitialScreen_MouseUp(Button, ShiftState, MouseX, MouseY)
' Quits the application only when a user releases the mouse button.
Application.Exit()
