KeyUp
KeyUp
KeyUp(KeyCode, Shift)
This event occurs when a key is released, regardless of the Screen focus.
Parameters of the KeyUp event
Name
Description
KeyCode
Integer identifying the ASCII character of the pressed key
Shift
Displays the shortcut key used with the pressed key. Possible values are 4: SHIFT key, 8: CTRL key, or 12: CTRL + SHIFT keys
The next script contains an example of using this event.
Sub Screen1_KeyUp(KeyCode, Shift)
  ' Displays a message box when a user
  ' releases a key
  MsgBox "Key code: " & KeyCode
NOTE
For a list with all key codes available for the KeyCode parameter, please check the article Keys Enumeration on Microsoft Developer Network.
