ShowTopScale
ShowTopScale
Boolean If this property is set to True, the main Horizontal Axis is displayed on top of the grid. Otherwise, it is not displayed. Default value is False. The next script contains an example of using this property.
Sub CommandButton1_Click()
  Set Chart = Screen.Item("E3Chart1")
  Chart.ShowTopScale = Not Chart.ShowTopScale
