<< Click to Display Table of Contents >> HorScaleEnd |
Determines the final value applied on a grid's main horizontal scale. This value can either be numerical for XY E3Charts or data for E3Charts with fixed-time scales. For real-time E3Charts this property is not applied, which uses the TimeSpan property instead. The next script contains an example of using this property.
Sub ComboBox1_Change()
' Defines which query to display
current_query_index = ListIndex
Set E3Chart1 = Screen.Item("E3Chart1")
i = 0
For Each query In E3Chart1.Queries
If i = current_query_index Then
' Retrieves everything
query.FieldFilter(0) = "" 'Retrieves all
Set current_query = query
Else
' to prevent slowing down the operation
query.FieldFilter(0) = "<0" 'Do not retrieve
' anything, to prevent slowness
End If
i = i + 1
Next
' Only displays pens using the current query
For Each pen In E3Chart1.Pens
pen.Visible = (pen.QueryName = current_query.Name)
Next
' Updates all queries
E3Chart1.Queries.UpdateData()
Screen.Item("E3Chart1").HorScaleBegin = Now - 0.001
Screen.Item("E3Chart1").HorScaleEnd = Now
