<< Click to Display Table of Contents >> HorGrid |
Determines the line type applied to an E3Chart's horizontal grid. The available options are described on the next table.
Available options for the HorGrid property
Option |
Description |
0 - Solid |
Applies a solid line on an E3Chart's horizontal grid |
1 - Dash |
Applies a dashed line on an E3Chart's horizontal grid |
2 - Dot |
Applies a dotted line on an E3Chart's horizontal grid (default) |
3 - Dashdot |
Applies a dash-dot line on an E3Chart's horizontal grid |
4 - Dashdotdot |
Applies a dash-dot-dot line on an E3Chart's horizontal grid |
5 - Invisible |
Applies an invisible line on an E3Chart's horizontal grid |
The next script contains an example of using this property.
Sub CommandButton1_Click()
Set E3Chart1 = Screen.Item("E3Chart1")
Old = E3Chart1.HorGrid
For i = 0 To 5
E3Chart1.HorGrid = i
MsgBox "E3Chart1.HorGrid =" & CStr(i)
Next
MsgBox "Return"
E3Chart1.HorGrid = Old
