Simple
Simple
In a Simple Link, the value in the Source column is copied to the property each time the first one is modified.
Simple Link
Simple Link
To use this resource, follow these procedures:
1.Right-click an object and select the Properties option.
2.Select the Links tab, click the Link column of a property, and then select the Simple Connection Simple Connection option.
3.In the Source column, click AppBrowser to indicate a property to create a reference or write down an expression in this column.
