<< Click to Display Table of Contents >> Bi-directional |
A Bi-directional Link is similar to a Simple Link. However, if there is a variation in this property, its value is copied to the source, thus generating a bi-directional Link.
Bi-directional Link
To use this resource, follow these procedures:
1.Right-click an object and select the Properties option.
2.Select the Links tab, click the Link column of a property, and then select the Bi-directional Connection option.
3.In the Source column, click to indicate a property to create a reference or write down an expression in this column.
