MouseDown |
MouseDown(Button, ShiftState, MouseX, MouseY)
Occurs when any mouse button is pressed on a Screen. Use the MouseDown event to determine specific actions when a user clicks a Screen. The parameters of this event are described on the next table.
Available parameters on the MouseDown event
Name |
Description |
Button |
Shows the mouse button pressed. Possible values for this parameter are 1: The mouse button pressed is the left one, 2: The mouse button pressed is the right one, or 4: The mouse button pressed is the middle one |
ShiftState |
Shows the key pressed along with the mouse button. Possible values for this parameter are 4: SHIFT key, 8: CTRL key, or 12: CTRL + SHIFT keys |
MouseX |
Shows the X coordinate where the mouse button was clicked on a Screen |
MouseY |
Shows the Y coordinate where the mouse button was clicked on a Screen |
Example:
Sub InitialScreen_MouseDown(Button, ShiftState, MouseX, MouseY)
'Shows a message box with
'the mouse pointer coordinates
MsgBox "X Coordinate: " & MouseX & _
vbNewLine & "Y Coordinate: " & MouseY
