XC_Pump |
The XControl XC_Pump simulates a pump's status, according to the settings of XObject XO_Pump.
1.Insert a new XControl in the library, named as "XC_Pump".
2.Insert an image of a pump, added previously as a Resource.
Pump
3.Insert a Text and a Display object, according to the next figure.
Text and Display
4.On the pump's drawing, right-click it and select the Convert to symbol and Explode symbol options.
NOTE |
This XControl is inserted on the Initial Screen, over the images of pumps. For that, adapt the size of the Pump figure with the size of the pump images on the Screen, making it easy to further insert other objects. |
5.Change the OverrideFillMode property to 2 - SolidFill and the OverrideFillColor property to the gray color (RGB(150, 150, 150)).
OverrideFillColor and OverrideFillMode properties
6.On the Properties tab, create the Properties shown on the next figure.
Properties tab
7.Texts must create the name of the linked XO_Pump object. In the Texts' Value property, create a Simple Link with the Name property of the XO_Pump object using the Source property.
Link with the Value property
8.The Text with pump's name can show on top or at the bottom of the figure, depending on the position of the object on the Screen. Create a Simple Link in bottom Text's Visible property with the Bottom property of object XC_Pump.
9.For the Text on top, create a Simple Link in the Visible property with the expression "NOT XC_Pump.Bottom".
Link between Value and Visible properties
10.In the object representing a pump, create a Digital Link in the OverrideFillColor property, according to the next figure.
11.In the Text object inserted near the pump, let's display that pump's status (On or Off). To do so, create a Digital Link in the Value property, according to the next figure.
12.In the Display object, let's show the pump's rotation speed. To do so, let's change the object's letter (L: Low, M: Medium, and H: High) and color. To change the letter, create a Table Link in the Value property with the Speed Property of the object XO_Pump, according to the next figure.
13.To change a Display's color, create a Table Link from the ForegroundColor property to the Speed property.
Table Link in the ForegroundColor property
14.For this Display not to be displayed if the pump is turned off, create a Simple Link from the Display's Visible property to the Status Property of the object XO_Pump.
15.Save the changes and register the library.
