Windows 11 |
On Windows 11, follow these procedures:
1.Click the Start menu.
2.Select the All apps option and select the Windows Tools item.
3.Double-click Internet Information Services (IIS) Manager.
4.Select the Default Web Site item on the Connections panel, and then select the Default Document option on the central frame.
IIS Default Document on Windows 11
5.Click Open Feature and Add on the Actions panel, type "e3web.asp" on the Name field, and then click OK.
IIS Add Default Document window on Windows 11
6.After these procedures, the client computer can access the web server using Edge.
