Log Configuration |
Users can define the minimum time to log a function on Full logs. Functions that last less than this time are not logged.
Users can define a time, in milliseconds, that a function must be executing so that a warning is generated (EcoLogWarning) informing that this function is probably locked.
Users can define which log sections are enabled. Sections can be subdivided into modules, so users can enable each module separately.
