Properties
Properties
This section contains information about the properties of a Screen object.
NOTE
Elipse E3 uses the Himetric system to define coordinates and widths. In this system, each logical unit is the equivalent of a thousandth of a centimeter, that is, every 1,000 units correspond to one centimeter. Thus, this is the standard adopted in the description of Elipse E3 properties, when applicable.
The available properties on this section are the following:
AllowContextMenu
AllowZoomChange
BackgroundColor
Caption
FillStyle
ForegroundColor
GradientStyle
Layer
PictureFile
PicturePosition
RenderQuality
ScreenAlignment
