<< Click to Display Table of Contents >> AckFailure |
AckFailure(FailureName)
This method must be used to acknowledge a failure generated by the ReportFailure method and, therefore, remove that failure from the list of failures in E3 Admin. The FailureName parameter indicates a user-defined name for this failure.
