LineStyle
LineStyle
Enum Determines the line style of Ellipse, Rectangle, and Rounded Rectangle objects. The available options for this property are described on the next table.
Available options for the LineStyle property
Option
Description
0 - rv2NoBorder
Line remains transparent
1 - rv2Solid
Line appears solid (default)
2 - rv2Dashed
Line appears dashed
3 - rv2Dot
Line appears dotted
4 - rv2DashDot
Line appears with a dash-dot pattern
5 - rv2DashDotDot
Line appears with a dash-dot-dot pattern
6 - rv2Double
Line appears with double the width indicated in the LineWeight property
