LineStyle
LineStyle
Enum Determines the line style of a Picture. The available options for this property are described on the next table.
Available options for the LineStyle property
Option
Description
0 - rv2NoBorder
Line remains transparent (default)
1 - rv2Solid
Line appears solid
2 - rv2Dashed
Line appears dashed
3 - rv2Dot
Line appears dotted
4 - rv2DashDot
Line appears with a dash-dot pattern
5 - rv2DashDotDot
Line appears with a dash-dot-dot pattern
6 - rv2Double
Line appears with double the width indicated in the LineWeight property
