SummaryFunc |
Determines the type of function used to process values from the field specified in the DataField, property, as listed on the next table. This property is only valid when the SummaryType property is different from 0 (zero).
Available options for the SummaryFunc property
Option |
Description |
0 - rv2Sum |
Calculates the sum of all values inside the interval of specified totals (default for group, page or Section Report) |
1 - rv2FAvg |
Calculates the average of all values inside the interval of specified totals (group, page or Section Report) |
2 - rv2Count |
Counts the number of values inside the interval of specified totals (group, page or Section Report) |
3 - rv2Min |
Shows the minimum value inside the interval of specified totals (group, page or Section Report) |
4 - rv2Max |
Shows the maximum value inside the interval of specified totals (group, page or Section Report) |
5 - rv2Var |
Calculates the variance of values inside the interval of specified totals (group, page or Section Report) |
6 - rv2VarP |
Calculates the population's variation of values inside the interval of specified totals (group, page or Section Report) |
7 - rv2StdDev |
Calculates the standard deviation of values inside the interval of specified totals (group, page or Section Report) |
8 - rv2StdDevP |
Calculates the population's standard deviation of values inside the interval of specified totals (group, page or Section Report) |
9 - rv2DSum |
Calculates the sum of all distinct values inside the interval of specified totals (group, page or Section Report) |
10 - rv2DAvg |
Calculates the average based on distinct values inside the interval of specified totals (group, page or Section Report) |
11 - rv2DCount |
Counts the number of distinct values inside the interval of specified totals (group, page or Section Report) |
12 - rv2DVar |
Calculates the variance of distinct values inside the interval of specified totals (group, page or Section Report) |
13 - rv2DVarP |
Calculates the population's variance of distinct values inside the interval of specified intervals (group, page or Section Report) |
14 - rv2DStdDev |
15 - rv2DStdDevP |
Calculates the population's standard deviation of distinct values inside the interval of specified totals (group, page or Section Report) |
