SummaryType |
Determines the type or level of summary to generate. The available options for this property are described on the next table.
Available options for the SummaryType property
Option |
Description |
0 - rv2NoST |
Do not generate a summary (default) |
1 - rv2GrandTotal |
Specifies that the whole content of a Section Report is summarized |
2 - rv2PageTotal |
Specifies that a per-page subtotal is generated |
3 - rv2SubTotal |
Specifies that a subtotal for each group is generated, defined in the SummaryGroup property |
4 - rv2PageCount |
Specifies a page counter |
