<< Click to Display Table of Contents >> Style |
Determines the style of the bar code. The available options for this property are described on the next table.
Available options for the Style property
Option |
Description |
0 - rv2NoBarcode |
Default bar code style |
1 - rv2Ansi39 |
ANSI 3 of 9 (Code 39) bar code style. Uses letters, numbers, -,*, $, /, +, %, etc. |
2 - rv2Ansi39x |
Extended ANSI 3 of 9 (Extended Code 39) bar code style. Uses full ASCII characters |
3 - rv2Code_2_of_5 |
2 of 5 bar code style. Uses only numbers |
4 - rv2Code25intlv |
Interleaved 2 of 5 bar code style. Uses only numbers |
5 - rv2Code25mat ou rv2Matrix_2_of_5 |
Matrix 25 bar code style |
6 - rv2Code39 |
Code 39 bar code style. Uses letters, numbers, -, *, $, /, +, %, etc. |
7 - rv2Code39x |
Extended Code 39 bar code style. Uses full ASCII characters |
8 - rv2Code_128_A |
Code 128 A bar code style. Uses numbers, punctuation, or letters |
9 - rv2Code_128_B |
Code 128 B bar code style. Uses Strings, numbers, punctuation, or letters |
10 - rv2Code_128_C |
Code 128 C bar code style. Uses only numbers |
11 - rv2Code_128auto |
Code 128 Automatic bar code style. Uses full ASCII characters. Automatically selects codes between 128 A, B, and C to configure the smallest value in the bar code |
12 - rv2Code_93 |
Code 93 bar code style. Uses letters, numbers, -, *, $, /, +, %, etc. |
13 - rv2Code93x |
Extended Code 93 bar code style. Uses full ASCII characters |
14 - rv2MSI |
MSI Code bar code style. Uses only numbers |
15 - rv2PostNet |
PostNet bar code style. Uses only numbers and a check digit |
16 - rv2Codabar |
Codabar bar code style. Uses A, B, C, D, +, -, :, /, or numbers |
17 - rv2EAN_8 |
EAN-8 bar code style. Uses only numbers (seven numbers and a check digit) |
18 - rv2EAN_13 |
EAN-13 bar code style. Uses only numbers (12 numbers and a check digit) |
19 - rv2UPC_A |
UPC-A bar code style. Uses only numbers (11 numbers and a check digit) |
20 - rv2UPC_E0 |
UPC-E1 bar code style. Uses only numbers. Used for UPC zero-compression symbols. In the Caption property, users can enter six digits of a UPC-E code or 11 digits. If an 11-digit code is inserted, then this bar code converts it to six UPC-E digits, if possible. Otherwise, converts from 11 to six UPC-E digits and nothing is displayed |
21 - rv2UPC_E1 |
UPC-E1 bar code style. Uses only numbers. The width of input data of UPC E1 is six number characters |
22 - rv2RM4SCC |
Royal Mail RM4SCC bar code style. Uses only letters and numbers and a check digit. This bar code is used in Great Britain |
23 - rv2UCCEAN128 |
UCC/EAN_128 bar code style. Uses full ASCII characters. This special version of Code 128 is used on HIBC applications |
24 - rv2QRCode |
2D bar code style that allows number, alphanumeric, and binary characters, in addition to kanji and kana characters |
25 - rv2Code49 |
High-density 2D bar code style containing between two and eight rows with eight characters each |
26 - rv2JapanesePostal |
Bar code style used by the Japanese mail system |
27 - rv2Pdf417 |
High-density 2D bar code style that allows encoding up to 1108 bytes of information |
28 - rv2EAN128FNC1 |
Alphanumeric bar code style to identify containers in the shipping industry |
29 - rv2RSS14 |
Bar code style formed by 14 number characters |
30 - rv2RSS14Truncated |
Bar code style formed by 14 number characters, including 0 (zero) or more digits for use in small items |
31 - rv2RSS14Stacked |
Bar code style formed by 14 number characters on two rows for a smaller width |
32 - rv2RSS14StackedOmnidirectional |
33 - rv2RSSExpanded |
Bar code style formed by 14 number characters, including information such as weight and best-before dates |
34 - rv2RSSExpandedStacked |
Bar code style formed by 14 number characters, including information such as weight and best-before dates, stacked on two rows for a smaller width |
35 - rv2RSSLimited |
36 - rv2DataMatrix |
High-density 2D bar code style with square modules arranged in a square or rectangular matrix pattern |
37 - rv2MicroPDF417 |
2D bar code style derived from style rv2Pdf417, allows configuring up to 150 bytes, 250 number characters or 366 digits |
38 - rv2MicroQRCode |
2D bar code style indicated for applications that use small amounts of data |
39 - rv2MaxiCode |
Special bar code style that uses 256 characters, indicated for specific amounts of data |
40 - rv2GS1QRCode |
2D bar code style that is a subset of style rv2QRCode |
41 - rv2GS1DataMatrix |
2D bar code style used in health industry |
42 - rv2Aztec |
2D bar code style that supports ASCII characters from 0 (zero) to 255 |
64 - rv2IntelligentMail |
Bar code style used for domestic mail in the US |
65 - rv2ITF14 |
Interleaved 2 of 5 bar code style |
66 - rv2Code_11 |
Bar code style that encodes numbers (0-9), hyphen (-), and start and stop characters, used for telecommunication devices |
67 - rv2SSCC_18 |
Bar code style composed by 18 characters to identify individual containers |
68 - rv2Telepen |
Bar code style composed by a start character, a check digit, and a stop character, used in the manufacturing industry |
69 - rv2Pharmacode |
Bar code style composed only by numbers between 3 (three) and 131070, used by the pharmaceutical industry |
70 - rv2PZN |
Bar code style with the same algorithm of style rv2Code39, except that uses only digits between 0 (zero) and 9 (nine), used to identify medicine and health-care products in Germany |
71 - rv2HIBCCode128 |
Bar code style that uses the same algorithm of style Code 128, used to identify health care products |
72 - rv2HIBCCode39 |
Bar code style that uses the same algorithm of style rv2Code39, used to identify health care products |
73 - rv2ISBN |
ISBN (International Standard Book Number) bar code style |
74 - rv2ISSN |
ISSN (International Standard Serial Number) bar code style |
75 - rv2ISMN |
ISMN (International Standard Music Number) bar code style |
76 - rv2IATA_2_of_5 |
Bar code style that is a variation of style rv2Code_2_of_5, except that uses only numbers with a check digit |
77 - rv2BC412 |
Bar code style that uses numbers and characters from A to Z, used to identify semiconductor wafers |
78 - rv2Plessey |
1D bar code style that uses hexadecimal digits, mainly used by libraries |
79 - rv2IntelligentMailPackage |
Bar code style more efficient than style rv2IntelligentMail |
