RemoveItem
RemoveItem
RemoveItem(pvargIndex)
Removes items from a List. This method has the pvargIndex parameter, which specifies an item to exclude, starting at 0 (zero). That is, the first element is 0 (zero), the second element is 1 (one), and so on. The next script contains an example of using this method.
Sub CommandButton2_Click()
  List1.SetFocus
  ' Checks if this list has selected items
  If List1.ListCount >= 1 Then
    ' If there is no selection,
    ' selects the last item on this list.
    If List1.ListIndex = -1 Then
      List1.ListIndex = List1.ListCount – 1
    End If
    List1.RemoveItem(List1.ListIndex)
  End If
