AddItem |
AddItem([pvargItem], [pvargIndex])
This method is used to add items to a List. The pvargItem parameter is a String containing a text to add to a List and, if omitted, adds an empty String. The pvargIndex parameter is the index of a text on a List and, if omitted, the value of the pvargItem parameter is added as the last item on the List. The next script contains an example of using this method.
Sub CommandButton1_Click()
EntryCount = EntryCount + 1
ListBox1.AddItem(EntryCount & " - Selection")
