<< Click to Display Table of Contents >> UseDefaultPrinter |
Configures the Line Printer object to use Windows default printer. Default value for this property is True.
NOTES |
•If this property is configured as False and the PrinterName property is configured with an empty String, users cannot print and the PrinterStatus property returns the value 0 (zero, psUnknown). •Windows default printer for the currently logged-in user may be different from the default printer used by E3 Server. This printer is identified by the icon |
