Style
Style
Text This property allows specifying a CSS (Cascade Style Sheet) style for a text, replacing the global style. This property's value must be a valid CSS String, otherwise this property is ignored. Default value of this property is an empty String (Elipse E3 uses operating system's default). The next script contains an example of using this property.
Sub Report1_OnBeforePrint
  Label1.Style = "font-family: Times; font-weight: bold;_
    text-align: center; color: RGB(255, 255, 0)"
