AdviseType |
Controls the Advise mode. The available options are described on the next table.
Available options for the AdviseType property
Option |
Description |
0 - AlwaysInAdvise |
This I/O Tag is kept updated if the AllowRead property is equal to True |
1 - AdviseWhenLinked |
This I/O Tag is only updated if the AllowRead is equal to True and it is linked to any active object, for example a Display on an open Screen or an enabled alarm, among others. The I/O Tag link for this purpose can be performed on properties Value, RawValue, TimeStamp, Quality, and Bit00 to Bit31 from the I/O Tag (default) |
The next script contains an example of using this property.
Sub CommandButton3_Click()
MsgBox Application._
Application.GetObject("Driver1.Tag1").AdviseType
