Bit00 to Bit31 |
Bit properties Bit00 to Bit31 all represent the 32 bits in I/O Tag's Value property, where Bit00 is the least significant bit and Bit31 is the most significant bit. By modifying each one of these bits implies in modifying I/O Tag's Value property, and vice versa, but this only happens when the UseBitFields property is set to True. Default value of these properties is False.
