AdviseType |
Controls the Advise mode. The available options are described on the next table.
Available options for the AdviseType property
Option |
Description |
0 - AlwaysInAdvise |
The I/O Block is updated if the AllowRead property is set to True |
1 - AdviseWhenLinked |
The I/O Block is updated only if the AllowRead property is set to True, and the I/O Block is associated to an active object, that is, one Display on an open Screen or an enabled Alarm, among others. An I/O Block link for this purpose can be assigned to the Value, RawValue, Quality, and from Bit00 to Bit31 for I/O Block Element properties, and Quality and TimeStamp for I/O Block properties (default) |
