<< Click to Display Table of Contents >> StopAcquisition |
StopAcquisition()
Disables storing records by period in a Historic, regardless of the value specified in the ScanTime property. Storing by period is disabled until the StartAcquisition method is used. Default behavior of a Historic object is start an application with storage recording enabled. The next script contains an example of using this method.
Sub Hist1_OnStartRunning()
' Disables Historic as soon as it starts.
StopAcquisition()
