<< Click to Display Table of Contents >> SummaryFunc |
Determines the type of function used for processing field values specified in the DataField property, as described on the next table. This property is only valid when the SummaryType property is different from 0 (zero).
Available options for the SummaryFunc property
Option |
Description |
0 - ddSFSum |
Calculates the sum of all values inside the range of specified total values (default for group, page, or Report) |
1 - ddSFAvg |
Calculates the average of all values inside the range of specified total values (group, page, or Report) |
2 - ddSFCount |
Counts the number of values inside the range of specified total values (group, page, or Report) |
3 - ddSFMin |
Displays the lowest value (minimum value) inside the range of specified total values (group, page, or Report) |
4 - ddSFMax |
Displays the highest values (maximum value) inside the range of specified total values (group, page, or Report) |
5 - ddSFVar |
Calculates the variance of values inside the range of specified total values (group, page, or Report) |
6 - ddSFVarP |
Calculates the population variance of values inside the range of specified total values (group, page, or Report) |
7 - ddSFStdDev |
Calculates the standard deviation of values inside the range of specified total values (group, page, or Report) |
8 - ddSFStdDevP |
Calculates the population standard deviation of values inside the range of specified total values (group, page, or Report) |
9 - ddSFDSum |
Calculates the sum of all distinct values inside the range of specified total values (group, page, or Report) |
10 - ddSFDAvg |
Calculates the average based on distinct values inside the range of specified total values (group, page, or Report) |
11 - ddSFDCount |
Counts the number of distinct values inside the range of specified total values (group, page, or Report) |
12 - ddSFDVar |
Calculates the variance of distinct values inside the range of specified total values (group, page, or Report) |
13 - ddSFDVarP |
Calculates the population variance of distinct values inside the range of specified total values (group, page, or Report) |
14 - ddSFDStdDev |
Calculates the standard deviation of distinct values inside the range of specified total values (group, page, or Report) |
15 - ddSFDStdDevP |
Calculates the population standard deviation of distinct values inside the range of specified total values (group, page, or Report) |
