SummaryType |
Determines the type or level of summary to generate. The available options for this property are described on the next table.
Available options for the SummaryType property
Option |
Description |
0 - ddSMNone |
Summaries are not generated (default) |
1 - ddSMGrandTotal |
Specifies that the whole Report content is summarized |
2 - ddSMPageTotal |
Specifies that a subtotal by page is generated |
3 - ddSMSubTotal |
Specifies that a subtotal for each group is generated, defined in the SummaryGroup property |
4 - ddSMPageCount |
Specifies a page counter |
