<< Click to Display Table of Contents >> Item |
Item(ItemId)
This method returns an Event or User Event object from the Collection of Events of any Elipse E3 object. If this parameter is a text, the ItemId parameter specifies the name of an object to access. An object can also be accessed by a numerical index. This index must range from 1 (one) to Count. If the object does not exist, or its index is invalid, a script error occurs.
