UaNodeId
UaNodeId
Indexed Property Returns an OPC UA Node Identifier-type object, with the configuration of the Node that identifies a field from an OPC UA query on a certain OPC UA server. In Elipse E3 Studio this property is only represented by an icon, on the Id column of the Query's field configuration. This is a read-only property.
