<< Click to Display Table of Contents >> VerifyXQuery |
VerifyXQuery([pVarOutErrors])
Checks whether the syntax of the script indicated in the Script property is correct. This method returns True if the syntax is correct and False if the syntax is wrong. The optional output parameter pVarOutErrors contains a String detailing the result of that check.
