DstHiValue |
This property specifies the highest value reached by the property. The next script contains an example of using this property.
Sub DstHiValue_ValueChange()
On Error Resume Next
Dim Bind
Set Bind = Screen.Item("ScrollBar1").Links.Item("Value")
Screen.Item("ScrollBar1").Max = Value
If Bind Is Nothing Then
MsgBox "ScrollBar1 has no link."
Else
MsgBox "ScrollBar1 is linked to " & Bind.Source & "'"
MsgBox "Changing DstHiValue from " &_
Bind.DstHiValue & " to " & Value
Bind.DstHiValue = Value
End If
