CurrentSubConditionName
Text Determines the name of the last active alarm condition. This is a read-only property. Available options for this property are described on the next table.
Available options for the CurrentSubConditionName property
OPTION
DESCRIPTION
LOLO
Analog Alarm on a Very Low range
LO
Analog Alarm on a Low range
HI
Analog Alarm on a High range
HIHI
Analog Alarm on a Very High range
DB
Dead Band Alarm
ROC
Rate Of Change Alarm
DIG
Digital Alarm
Default value of this property is an empty String.
NOTE
For Discrete-type Alarm Sources, this property assumes the name of the user-defined Subcondition, on the Discrete tab of properties of this type of Alarm.
