<< Click to Display Table of Contents >> Methods |
On a Legend, several columns can be selected. Each column displays a type of information and contains a corresponding name and value. The following table displays all possible columns on a Legend.
Available options to identify a Legend column
Option |
Name |
Description |
AverageY |
10 |
AverageY |
Shows a Pen's average value in this interval |
BeginX |
13 |
XBegin |
Shows a cursor's initial position |
BeginY |
17 |
YBegin |
Shows the interpolated point where the initial cursor meets a Pen |
DiffX |
15 |
DiffX |
Shows the difference between initial and final cursors |
DiffY |
16 |
DiffY |
Shows the difference between initial and final interpolated points on the Y Axis |
EndX |
14 |
XEnd |
Shows a cursor's final position |
EndY |
18 |
YEnd |
Shows the interpolated point where the final cursor meets a Pen |
MaximumY |
12 |
MaxY |
Shows a Pen's maximum value in this interval |
MinimumY |
11 |
MinY |
Shows a Pen's minimum value in this interval |
Pen color |
6 |
Color |
Shows a Pen's color |
Pen description |
5 |
Description |
Shows a Pen's DocString property |
Pen name |
0 |
Name |
Shows a Pen's name |
ScaleYMax |
20 |
ScaleYMax |
Shows the maximum value of a vertical scale |
ScaleYMin |
21 |
ScaleYMin |
Shows the minimum value of a vertical scale |
Status |
7 |
Status |
Shows a Pen's status |
Unit |
19 |
EU |
Shows a Pen's engineering unit |
X tag name |
1 |
TagX |
Shows a Tag's name linked to the X Axis |
X tag value |
3 |
TagXValue |
Shows a search value on X Axis |
XScale |
8 |
ScaleX |
Shows the X Axis' name linked to a Pen |
Y tag name |
2 |
TagY |
Shows Tag's name linked to the Y Axis |
Y tag value |
4 |
TagYValue |
Shows a search value on Y Axis |
YScale |
9 |
ScaleY |
Shows the Y Axis' name linked to a Pen |
The available methods on this section are the following:
•Item
