ChangeColumnPos
ChangeColumnPos
ChangeColumnPos(Source, Dest)
Swaps two columns. This method contains the following parameters:
Source: Index of the column to swap to Dest
Dest: Index of the column to swap to Source
The next script contains an example of using this method.
Sub CommandButton1_Click()
  Screen.Item("E3Chart1").Legend.ChangeColumnPos 1, 2
