<< Click to Display Table of Contents >> Click |
Click()
This event occurs when the left mouse button is pressed on an object. This event does not occur if this object is not visible, or if its Enabled property is set to False. Visibility of an object depends on three factors: Visible property set to True, parent object visible, and object's Layer property present on a Screen layer.
