<< Click to Display Table of Contents >> OnLegendClick |
OnLegendClick(Row, Col, RowData)
Occurs whenever users click one of the Legend rows. The Row and Col parameters indicate, respectively, the row and column clicked. The RowData parameter is the Legend's Pen index where the click occurred. The next script contains an example of using this event.
Sub E3Chart1_OnLegendClick(Row, Col, RowData)
Set text = Screen.Item("Text1")
text.Value = Legend.Item(col).Name & " " & _
Pens.Item(RowData).Name
