ShowTitle |
If this property is set to True, E3Chart's main title is visible. Otherwise, it remains invisible. The Title property contains a title to display on an E3Chart. The next script contains an example of using this property.
Sub CommandButton1_Click()
Set E3Chart1 = Screen.Item("E3Chart1")
oldTitle = E3Chart1.Title
oldShowTitle = E3Chart1.ShowTitle
E3Chart1.Title = "Test!"
MsgBox "Display"
E3Chart1.ShowTitle = True
MsgBox "Hide"
E3Chart1.ShowTitle = False
MsgBox "Return"
E3Chart1.Title = oldTitle
E3Chart1.ShowTitle = oldShowTitle
