FitAll |
FitAll([FitStyle])
Fits all Pens into an E3Chart. The optional parameter FitStyle indicates the way Pens fit at run time and, if omitted, assumes the value 0 (zero). Possible values for this parameter are 0: Fits both Axes at the same time, 1: Fits only the Vertical Axis, or 2: Fits only the Horizontal Axis.
