OnDrawRow |
OnDrawRow(Selected, Row, TextColor, BackColor)
This event contains the Selected parameter, which indicates whether a row is selected, the Row parameter, which indicates the number of the row currently being drawn, the TextColor parameter, which indicates a row's text color, and the BackColor parameter, which indicates the text's background color of a row.
If the color is modified within this event, this change is used by an E3Browser when drawing a row. Another important change is that if the GetColumnValue method is used within this event, the returned values are from the row currently being drawn, not from the selected row.
