<< Click to Display Table of Contents >> ShelveSelected |
ShelveSelected(Duration, Reason, [Operator])
Allows shelving the selected Alarms. If there is no selected Alarm in the E3Alarm, this method fails. Users can shelve an alarm, and in this case a new record is inserted on the Database indicating that shelving, and on the E3Alarm the corresponding row indicates it was shelved. The Duration parameter indicates a period of time, in minutes, in which the Alarms remain shelved. The Reason parameter indicates a reason for shelving. The Operator parameter is an optional String indicating the name of the operator who shelved the Alarm. This value is displayed on E3Alarm's Operator column. If omitted, the current Elipse E3 Viewer's user is used or "(No User)", if there is no user logged on. For the shelving itself, the logged-on user must have the Alarm shelving permission.
