<< Click to Display Table of Contents >> Variables in Viewer |
In a Viewer object, users can create Links to objects from Screens, as well as use them via scripts. Users can also insert Counter, Demo, Internal, and Timer Tags in Viewer, in addition to Viewer Folders and Queries. By using the AppBrowser, users can perform the following actions:
•Access a Viewer or one of its child objects from a Screen or a Screen control (Links or scripts)
•Viewer's child objects can access other Viewer's children, or Viewer itself (Links or scripts)
•A Viewer can access its own child objects (Links or scripts)
It is important to notice that a Link to a Viewer must use its real name, such as "Viewer1", and not simply "Application". In scripts, users can still use Application, which is a property of all objects returning a Viewer.
