Default Permissions
Default Permissions
Starting with version 6.6, Elipse E3 contains a series of permissions inherited when creating new users or groups, gathered in the Default Permissions item, shown on the next figure.
Options for default permissions of Elipse E3
NOTE
The administrator user, who must always be created in a new application to perform user control, always have all permissions granted, regardless of the settings in the Default Permissions item.
For each item on the Permissions tab, there is a series of permissions that can be configured for each user. The available options are described on the next tables.
Available options for Domains
Option
Description
Run Domain
Enables the execution of a Domain. The default value of this option is Not Allowed
Stop Domain
Stops a Domain. The default value of this option is Not Allowed
Edit Domain
Enables editing a Domain. The default value of this option is Not Allowed
Run as a service
Enables the execution of a Domain as a service. The default value of this option is Not Allowed
Configure users/groups
Allows configuring users and groups of users. The default value of this option is Not Allowed
Remote Domain access
Enables remote access to a Domain. The default value of this option is Not Allowed
Remote Domain write access
Enables remote writing access to a Domain. The default value of this option is Not Allowed
Write to runtime properties from Studio
Enables writing to the column of property values on the WatchWindow window at run time. The default value of this option is Not Allowed
Available options for Viewers
Option
Description
Server write access
Enables writing access to a server. The default value of this option is Allowed
Available options for Screens
Option
Description
Open Screen
Enables opening Screens. The default value of this option is Allowed
Available options for Alarms
Option
Description
Alarm acknowledgment
Enables acknowledging alarms. The default value of this option is Allowed
Delete unbound alarms
Enables removing alarms unbound to Alarm Sources. The default value of this option is Allowed
Shelve/Unshelve alarms
Enables shelving and unshelving alarms. The default value of this option is Allowed
Each item on the list of default permissions can be configured with one of the statuses on the next table.
Possible statuses for the Default Permissions item
Status
Description
Allowed Allowed
The option is allowed for all users or groups that automatically inherited the permissions defined in the Default Permissions item
Not Allowed Not Allowed
The options is not allowed for any user or group that automatically inherits the permissions defined in the Default Permissions item
NOTES
When opening an application created in version 6.5 in version 6.6, all options of the Default Permissions item are allowed.
When opening an application created in version 6.1 or earlier in version 6.6, the options of the Default Permissions item are allowed, except the Configure users/groups, which is always denied.
Converting an application created in version 6.5 or earlier and opened in version 6.6 is only effective when any option of the Default Permissions item is changed and saved.
